fixing steering clutches
brianspridejd
Post by brianspridejd » Wed Sep 17, 2008 5:27 pm
it took me an hour in a half to tare the hide end of my dozer apart last knight now im takeing clutches apart tonight hope to have pics tomarrow. Its going better than the last time at least I dont have to tare tranny apart. :)
im 23 and i have a 1940 jd h tractor ,a jd 420 dozer, a case vac 1947,a farmall a 193?, a farmall regualer 192? , a 1951 merc ,a1956 dodge 1 ton ,and a stover 1 lunger a ct2
brianspridejd
Post by brianspridejd » Fri Sep 19, 2008 9:00 am
I f you take the presure plates off your steering clutches with out messing with the clutch fingures do u still have to adjust
Post by Lavoy » Fri Sep 19, 2008 10:02 am
Unless the fingers were just adjusted before you took it off, they should be readjusted.
brianspridejd
Post by brianspridejd » Fri Sep 19, 2008 6:18 pm
I was just wodering because they never have been sence I got the maghine. but I wernt sure if just takeing the presure plate off would bother it. but I guse it would be a good thing to wate.
brianspridejd
Post by brianspridejd » Tue Oct 07, 2008 8:12 pm
shes going moveing turning It did the the trick the tool to adjust the pressure plate and cleening the discs
Users browsing this forum: No registered users and 55 guests
