JD1010C with a JD810 front end loader in need of a tooth
Rich Robert
Post by Rich Robert » Fri Sep 12, 2008 10:30 am
I have a JD1010C gas, industrial model with a front end loader. One of the teeth is broken on the bucket which i would like to replace. Its app. 8 "long and 2"wide attached using a split tongue arrangement with 2 3/8" bolts. It does not need to be new. Thanks
Rich/JD1010C and 1930 Model AA ford dump truck
Rich
jdemaris
Re: JD1010C with a JD810 front end loader in need of a tooth
Post by jdemaris » Fri Sep 12, 2008 1:00 pm
Rich Robert wrote:I have a JD1010C gas, industrial model with a front end loader. One of the teeth is broken on the bucket which i would like to replace. Its app. 8 "long and 2"wide attached using a split tongue arrangement with 2 3/8" bolts. It does not need to be new. Thanks
Here is a copy of the answer I posted to you in the other forum.
I have the same machine except my 1010 is a 1960 with a 810 front loader and a rear ripper.
The original Deere # for that tooth is U 12910 U. But, when you order it from Deere they send you something different without any sub numbers. They give you a generic replacement tooth needing a new type of shank to be installed. You can buy the new weld-on, or bolt-on shanks from many places. Deere basically markets stuff made by other companies.
I put weld on shanks on my front bucket, and can now buy teeth for $5 each just about anywhere.
Deere tooth catalog is at:
https://jdparts.deere.com/partsmkt/docu ... eethBR.pdf
I bought mine on sale in a kit from:
http://www.excavationsupply.com/BucketTeethIndex.htm
Users browsing this forum: No registered users and 184 guests
