Drive sprocket hitting roller
JOHNSIGY
Post by JOHNSIGY » Mon Aug 04, 2008 5:12 pm
I was using my 440 crawler to move some dirt and when I stopped I did a walk around and I noticed that the drive sprocket on the left side was hitting the lower track roller, not hard just nicking it alittle and I'm kind of lost as to where this movement could be coming from. I thought when I had that side apart last year that things seemed to be pretty good? Does anyone have any ideas as to what has started to go wrong.
John
CELSESSER
Post by CELSESSER » Mon Aug 04, 2008 6:51 pm
John,
Stick a prybar in one of the sprocket holes and see if you can wiggle the sprocket around. Sounds to me like you have probably lost a bearing in the final.
Chuck
tuney443
Post by tuney443 » Tue Aug 05, 2008 10:34 pm
I've just noticed mine is doing the same thing and I can see that the sprocket is wiggling some.
Found the skull to the mastodon in Hyde Park, youngest one ever found so far in the world in 2000.
JD35D midi exc.
JD410G TLB
JD450D Dozer
2 JD 440 track loaders
JD 420 track loader
JD 450C track loader
JOHNSIGY
Post by JOHNSIGY » Wed Aug 06, 2008 4:30 pm
Thanks guys it sounds like you have me pointed in the right direction. I did noticed some oil dripping onto the trackes and it looked like it was coming out of the seal behind the sprocket. I will check that bearing play tonight, and thanks again for the help.
John
Post by Ray III » Sat Aug 09, 2008 7:21 pm
If you need to keep using the machine for now and the bearings are loose, you can get some shims and put them under the bearing cap behind the final drive under the transmission until play is taken out. Won't fix worn bearings but it will keep something else from getting wrecked from excessive movement of parts for now.
