cracked head on 420c
lowboy
Post by lowboy » Thu Sep 29, 2005 8:46 pm
Hello guys
The machine shop says the head is cracked
Haven't seen it yet
Could this be like a chevy small block in that it doesn't matter?
What is one worth?
there is a head shop 100 miles from here what should a fix cost me ?
The machine shop says it's not fixable
They maybe covering there a##
What other heads will work?
Lowboy
Post by Lavoy » Thu Sep 29, 2005 10:25 pm
Cracked heads are not uncommon on 420's. They normally crack between the valves, can not be run, they will take on water if you do. I have had some fixed by a shop about 60 miles from me, but what he does is a lost art, and real hard to find anyone that can do it anymore. Add to that the fact that most repairs are $200-$400 just for the repair, then the regular machine work comes later.
420, 430, and early 440 are the same.
I have heads if you need one.
jdman
Post by jdman » Mon Oct 03, 2005 9:40 am
Yup, I Have 3 "Boat Anchors" In The Corner Of My Shop........ Its Cheaper And Easier To Buy A New One...... Then You Know Its Right.......
Jeff
lowboy
420 c head
Post by lowboy » Mon Oct 03, 2005 10:48 am
Hello guys
Took my head to a welding shop today
$65.00 to repair the crackAll totaled up with a cleaning and new seat it is 125.00 Guaranted for 12 months let's see if he's as good as he claims
Lowboy
Post by Lavoy » Mon Oct 03, 2005 1:32 pm
You would hope that if he is gauranteeing it, that he does good work.
/J^
Post by /J^ » Tue Oct 11, 2005 4:10 pm
I just wanted to ask and see if any one else has heard of someone fixing a head using their oven? From my understanding, the head is heated up to 400 or 450 degrees and then welded. The head is then put back in the oven and the temperature is dropped 50 degrees every half hour?
GC
Users browsing this forum: No registered users and 72 guests
