Blower fan
tuney443
Blower fan
Post by tuney443 » Wed Jul 09, 2008 8:42 pm
After running my 440 in this July heat made me wonder--is there a bolt -on blower fan for the Jimmy diesel.The heat coming off that sucker fan is unreal---I'm actually sweating just sitting down.
Found the skull to the mastodon in Hyde Park, youngest one ever found so far in the world in 2000.
JD35D midi exc.
JD410G TLB
JD450D Dozer
2 JD 440 track loaders
JD 420 track loader
JD 450C track loader
Post by Stan Disbrow » Thu Jul 10, 2008 8:37 am
I recall such a fan, and *think* it was first offered on the 440's. It may have not been offered until the 1010, though. You know how wetware can be! :P
Regardless, there are pusher fans available - well, I ought to say I've seen them, one needs a scorecard to tell what is and is not available these days - for all of the older crawlers.
Heck, I ought to switch the one out on my 420 as well. It does get rather toasty when using the poor old girl....
Later!
Post by Lavoy » Thu Jul 10, 2008 10:31 am
Pusher fan was available for the gassers, I have an NOS pusher fan kit for mine if I ever get it done.
BKahler
Post by BKahler » Thu Jul 10, 2008 1:41 pm
Lavoy wrote:Pusher fan was available for the gassers, I have an NOS pusher fan kit for mine if I ever get it done.
Its interesting that none were available for the diesels.
Do you think it would be possible to retrofit a pusher fan to a diesel?
If so any suggestions on where to look for such an animal?
Brad
Post by digitup2 » Thu Jul 10, 2008 7:06 pm
They don't happen to make a Hubber fan for the little two stroke Detroits do they .I haven't had a Hubber fan on anything older or smaller than a 550 .Got one on the new 650J and it was a 550 buck option they aren't cheap!!. Digitup.
Dave Seager
Post by Dave Seager » Thu Jul 10, 2008 7:27 pm
:o I worked for a small excavation contractor way back in the early '70's.They had a 350D shovel dozer that they used to change the fan on. I don't know how it worked or what they did, whether they changed the whole fan or whether there was a way to change the pitch :idea: (possibly take blades and hub off pulley, reverse hub and blades, put hub and blades back on pulley ???) I have no clue whether the clearances would allow this or not :o :roll: :?:
Dave
Creepy Crawler
Adjustable fan blades..
Post by Creepy Crawler » Thu Jul 10, 2008 7:46 pm
Dave ! I worked many years on Dozers and the old Internationals..TD-7 and TD-8's had reversable fan blades...Summer/Winter...Each blade had a cross "T" in the hub with an individual spring on each blade...To change them to flow out front or flow back You just had to press down on the end of the blade and turn it 180 degree turn to change the air flow...Hope I was able to shed some light on the adjustable ones....Brian [ Creepy Crawler]
Post by digitup2 » Fri Jul 11, 2008 6:14 am
That was probably a Hubber fan they were quite common on Allis's and Internationals and for quite a while standard issue on both .I have bought parts for my Hubber fans on line from them directly .The 36 inch fans on my HD21B's are both Hubber and the only dealer in Canada is Deere Industrial .When I went to order parts from Deere dealer they weren't interested in getting the spring and pin kit for me .I went to Hubber and they sent the new spring kit our directly to me.And even showed me how to install the kit .They are great to deal with and Deere dealer got there butts kicked over it !!I would amagine that you should be able to get a fan for a Detroit as easy as a Deere but they may cost considerable $ .Digitup.
Users browsing this forum: Google Adsense [Bot] and 30 guests
