Ignition
Ignition
Post by JD440ICD2006 » Sun Jul 06, 2008 2:10 pm
Take off distributor cap, remove cover to get to points. Turn ignition to the run position. Operate the points and see if you are getting a spark between them. If so, try starting and see if you still get a spark. If you are getting spark, remove a spark plug, ground it, and start to make sure you get spark at tip.
If those test work, make sure you have fuel.
roofdog
Post by roofdog » Sun Jul 06, 2008 4:48 pm
took cap off points are not sparking either.
should of been a mechanic NOT a Roofer
Post by JD440ICD2006 » Sun Jul 06, 2008 5:08 pm
No fire at that point means you have an electrical issue. Trace the wires and make sure you have solid connections and a good ground. Start at the battery with a voltage tester, or anything to indicate power. You will find where the break in connection is.
Good luck and keep us posted.
Users browsing this forum: No registered users and 106 guests
