3 questions on 420c
lowboy
3 questions on 420c
Post by lowboy » Sun Sep 25, 2005 7:11 pm
Hello guys
Hope Katrinna and Rita didn't get ya And lets pray for those it did!
I have 3 questions.
1. It looks like if i take the" bell housing " off i'm going to get into the
transmission. Am I getting a hornets nest or will this not affect me to much?
I guess I had 1 questions and 2 info needed
2 I need a picture of the factory 3 point
I t looks like mine was home made
The red paint stops at the rear of the bell housing
Is there a way to tell, other than paint,if the rearend is the same year and
if so How. I don't see any tags
Lowboy
P.S. What is the weight of this machine? 3rd question
Lowboy
Post by Lavoy » Mon Sep 26, 2005 9:29 am
By puling the center section, you will only get to the front of the transmsiion, no internals. If you have a reverser, you will have access to it with the center section removed.
Look in the pictures page and there should be a pic of a 3PT crawler.
No tags were used other than serial number tags. No way to tell if it is later or not, but would not be uncomnon to have been replaced.
Post by Stan Disbrow » Mon Sep 26, 2005 1:37 pm
Red paint? Where's the red paint? Should be either green (ag) or yellow (ind). Perhaps something was rebuilt along the way and repainted with a red primer? I can tell you that all my Deere machines (M, 40T, 420C, 430W) have no primer under the factory paint. In that era, they usually dipped the entire machine in a paint bath! :p So, final color is also the primer! :p :p
My 1958 420C, with differential-style direction reverser, 5-roller track frame with 12" pads and model 62 6-foot manual angle/tilt blade, and no 3-pt weighs in at 7200 pounds fully wet (measured by weighing the truck/trailer/crawler and then re-weighing the truck/trailer after the crawler was removed). Weight, of course will vary widly based on what equipment a given machine has. :)
Howard Yoder
Post by Howard Yoder » Mon Sep 26, 2005 5:28 pm
I had a red 440 but it was painted that way by a blacktop company that probably painted all there equipment red it didn't come from deere like that.
Post by Lavoy » Mon Sep 26, 2005 8:03 pm
Now that you mention it, my brother had a red 420 with 90 loader, same song as Howard.
lowboy
red 420
Post by lowboy » Wed Sep 28, 2005 8:04 pm
Hello
i'm waiting on what Two cylinder says.
The red paint maybe something that somebody else did,
but it sure don't look like primer, I have used in the autobody trade
It is a bright red not a rust looking red
I maybe "hopeing" to have a 1 in a 1,000,000 find but I'll see what "they"
can't tell me
Lowboy
DiggerLarry
Post by DiggerLarry » Thu Sep 29, 2005 12:00 pm
I have an orange 420, I'm working on now. Don't know if Deere painted it that way or not but it appears they did. Deere would paint it any color you wanted, if you paid for it. If you are getting 2 Cylinder to do a serial number research, no definative way to know from that. It might have CJ code recorded but the code could mean anything. Dubuque didn't keep real good records or they no longer exist on what the CJ's were. All you can say is there was something different about that one. If it has a factory 3-point, that could be reason for the CJ code.
CCWKen
Post by CCWKen » Thu Sep 29, 2005 8:12 pm
Anyone have a "good" picture of a 3pt hitch?
Hey Lavoy, those pictures look like ebay pictures--small and blury. Is there a link to the originals or bigger pictures?
JD420C, Ford 3910, IH 2606, Kenbota G32XKS
Post by Lavoy » Thu Sep 29, 2005 10:34 pm
Damn Ken, sorry my pics aren't good enough for you, I'll shoot the webmaster tomorrow.
Barring that, you could of course right click on the pic, save it to your desktop, reopen it with photoshop or picture manager and blow it up and edit it any way you like.
CCWKen
Post by CCWKen » Sun Oct 02, 2005 9:38 pm
I don't mean to demean your pictures Lavoy but they get worse as they get bigger. They're great for identification, look and shape at the tractor level. But when someone asks for pictures of a 3pt hitch, a view of the whole tractor doesn't help much. If I run across parts, I'd like to know what they look like, whether the set is complete and how they're mounted.
If you don't have pics available, I understand. :?
Post by Lavoy » Mon Oct 03, 2005 8:59 am
I can take a pic of my 420, but to post it, it has to be lower resolution. I will try it this week sometime and see how it turns out.
Users browsing this forum: No registered users and 70 guests
