JD 450 Engine Rebuild
Brad
Post by Brad » Mon Jun 23, 2008 11:37 am
I'm rebuilding my JD 450 (S# T5F3M 076639)) engine out of machine. The original block (M53TF 117795T) was cracked so I obtained a replacement block (M5BTA 091895T). The old block was a 4.202 and it looks like the replacement block is a 4.219.
They have the same casting number T26933 but of course the sleeve bore is not the same.
Will I have a problem using this block in my rebuild (using the same head, crank shaft etc) to fit into my machine?
Any input would be appreciated.
Brad
JD 450 Dozer
Users browsing this forum: NevadaKid and 212 guests
