More 1010 Questions
cpjd450b
More 1010 Questions
Post by cpjd450b » Wed Sep 21, 2005 4:22 pm
I split the track today and the master pin had a tack of weld on the inside, should I re-tack it?
How would the fan belt come out, do you have to take off the hydraulic pump?
Why does the hydraulic pump disengage with a lever?
Thanks Chad
Post by Lavoy » Wed Sep 21, 2005 8:58 pm
If the pin fits tight, and the snap ring groove is good, should not need to tack it. If not, then it won't hurt anything.
Pump disconnect is for starting in cold weather. Not sure if you can snake the belt through the coupler or not. Take the grille off, and you should have better access through the front.
jdman
Post by jdman » Thu Sep 22, 2005 7:03 am
Hyd. Pump Has To Come Off....... It's Easy Tho... 2 Bolts And Loosen The Hyd. Lines... Slide It Off And Then The Belt Will Go On.....
Jeff
cpjd450b
Post by cpjd450b » Thu Sep 22, 2005 12:42 pm
Thanks alot for the info!!!
Chad
Chad
