How you're all getting it done?
brettjones
Post by brettjones » Fri Jun 20, 2008 1:09 am
I was just looking at Lavoy's latest work and I started wondering how everyone is stripping down their projects to bare metal.
I've been going through some old machine tools lately. Sand blasting is out of the question for these machines so I've been using synthetic abrasives to strip off many years of paint. It's a messy job and of course leaves a layer of dust throughout the shop. I cover the working lathes and mill, and try to clean up everything after I'm done, but it just gets everywhere.
Are you guys stripping paint/grime off outside or in a special area? How are you all dealing with the mess?
JD 1010c, outside blade, winch
country53
How you all getting it done
Post by country53 » Fri Jun 20, 2008 5:47 am
I made up an electrolysis tank out of an old cattle water tank, worked well for me.
CELSESSER
Post by CELSESSER » Fri Jun 20, 2008 7:23 am
country53,
How did you set up your electrolisis tank?
Chuck
country53
How you all gettin done
Post by country53 » Fri Jun 20, 2008 8:54 am
Post by Tigerhaze » Fri Jun 20, 2008 9:40 am
Hi Brett-
I've used chemical (aircraft) stripper for many years on my automotive restoration work. Instead of dust you get strips of paint or a gummy mess, depending on the paint used.
However it does a fairly good job on my projects and has the advantage of being able to be used right on the machine (do not need to disassemble parts and put in a tank). It sometimes takes multiple coats and scraping if there are several paint layers and doesn't really help much on surface rust.
It can be messy in its own way but is another option for you. If you decide to use this method, make sure you take safety precautions such as wearing chemical-resistant gloves and a respirator or at least goggles or safety glasses in a well-ventilated area.
