420 steering clutch
Johnneypopper
420 steering clutch
Post by Johnneypopper » Thu May 22, 2008 9:36 pm
hey all
ok i got my clutches apart and they are a bit oily but the steel plates and the pressure plate look good there not scuffed or warped but im noot sure the thickness they should be what all should i look for i want to make sure i replace everything i should also Lavoy how much would the upper idler and shaft be and would you have them in stock
Post by Lavoy » Fri May 23, 2008 6:16 am
The steels are about .093, if the fibers are oily, they need to be replaced. I have shafts and idlers on hand, idlers are $150, shafts are $50.
Users browsing this forum: No registered users and 214 guests
