440 steering clutch drum stuck
lastchancegarage
Post by lastchancegarage » Thu May 22, 2008 7:00 am
Is the steering clutch drum a press fit onto the splined hub? I've tried heating it carefully and tapping around the top of the splined hub with pry bars under the drum edge to apply pressure but no luck. How much force is needed to get the drum off? Anyone else have this problem? Thanks.
1959 JD 440 ICD dozer
195? ATC GT-25 dozer
Post by Lavoy » Thu May 22, 2008 7:21 am
I know in the past, I have had to put the drum in a press and push the shaft out.
lastchancegarage
Post by lastchancegarage » Thu May 22, 2008 8:05 am
At this point, I'm wondering if I should just leave it alone and go ahead with replacing the clutch discs. The only reason for removing was going to be cleaning the backside of the final case.
