440 ic cherry red manifold?
cardoc1975
Post by cardoc1975 » Tue May 20, 2008 7:36 am
Is it normal for the exhaust manifold to get cherry red after a while running.
jdemaris
Re: 440 ic cherry red manifold?
Post by jdemaris » Tue May 20, 2008 7:52 am
cardoc1975 wrote:Is it normal for the exhaust manifold to get cherry red after a while running.
No. That can be caused by several things - e.g. exhaust manifold getting thin and close to burning out; a leaking exhaust valve; an overly lean fuel mixture; and maybe a few that don't come to mind at the moment.
Post by NNAATZ » Tue May 20, 2008 7:54 am
no, check the timing or it may be running lean
H-D
Post by H-D » Tue May 20, 2008 2:38 pm
Expanding on NNAATZ's post: check to see that the advance mechanism in the distributor is functional. The Delco units were pretty reliable, but even they would have corrosion issues if not oiled occasionally. I've seen one of the other make distributors have the advance springs rust & break, leaving the timing fully advanced. When the initial timing was checked & reset, the engine was way weak. It's a good idea to check the advance function when you set the initial timing. HTH
Post by Ray III » Sun May 25, 2008 9:22 am
Don't you guys mean it could be running rich?
Post by JD440ICD2006 » Sun May 25, 2008 11:05 am
No, the leaner the mixture, the hotter the exhaust. I thought it would be the other way around too, but it is not.
I had a partial blockage in the fuel line on my 420W, it would turn part of the exhaust cherry hot.
Users browsing this forum: No registered users and 277 guests
