engine overhaul bo lindeman
spike
Post by spike » Sun Sep 11, 2005 10:49 pm
Aloha I am doing a restoration on abo lindeman.I live on the bib island of Hawaii.What i need is torque specs on rods cylinders head also valve clearance.Do i need to time my oil pump?Where can i get a carb kit? Any help would be greatly appreciated all i have is aparts book for bo lindeman Aloha Spike
Jimmy in NC
Post by Jimmy in NC » Sun Sep 11, 2005 10:55 pm
I don't have the toque specs for a BO but I imagine they are the same as a B. From what I've read and been told all of the motor end should be the same just like the M,40,420,430, etc. wheeled tractors are to the crawlers.
You may find better results looking for that info on the johnnypopper.com website. Just navigate to the message board using the link on the home page.
www.johnnypopper.com
As for the carb kit I think Roberts Carb Repair would be able to get you any parts you need and I think they even have instructional videos if you need that extra bit of insurance.
www.robertscarbrepair.com
You can also call Robert's at (712) 262-5311
Welcome to the board!
Jimmy in NC
Post by Lavoy » Mon Sep 12, 2005 11:22 am
Spike,
I can get a carb kit, they are not spendy.
I should have an I & T manual with torque specs, I will see if I can find it.
spike
Mahalo
Post by spike » Mon Sep 12, 2005 12:21 pm
Aloha thanx LavoyIam putting it together today .How much is acarb kit? Spike Aloha
Post by Lavoy » Mon Sep 12, 2005 12:46 pm
B carb kit is $25 with throttle shaft, gaksets, needle and seat. Not sure if I can get throttle shaft bushings anymore, but can check if you need them. I do need to know the carb number, there are 3 different kits.
spike
carb#
Post by spike » Mon Sep 12, 2005 10:58 pm
Aloha Lavoy Carb# dltx10 .Cast# on carb body .Any luck on torque Specs ? Let me know Carb kit cost + shipping& i will send $.Mahalo Spike
Post by Lavoy » Wed Sep 14, 2005 10:38 am
Spike,
Carb kit is no problem, take me a few days to get, $32.70 with freight.
Rods are 62 lbs
Head bolts are 96 lbs, 104 if you have the dark, heat treated studs.
Valves are .020 hot.
spike
Post by spike » Wed Sep 14, 2005 11:03 am
Thanks Lavoy.
Yes I want the carb kit.
Spike
Post by Lavoy » Wed Sep 14, 2005 9:00 pm
I will order it in the morning.
