PTO for JD 450C
reb
PTO for JD 450C
Post by reb » Fri May 02, 2008 9:04 am
I am looking for a pto shaft and related parts for my 450C crawler loader. It currently has just a block plate where the shaft goes. The JD part number for the shaft is : T20948 SHAFT,POWER
Thanks, Ross
JD430C
Post by JD430C » Fri May 02, 2008 9:57 pm
hi, i have a 450C parts tranny with the pto shaft, if i still need one let me know and i will try to take it apart this weekend.
andrew
reb
Post by reb » Fri May 02, 2008 10:05 pm
Andrew,
I need the shaft and related parts(the outer bolt on housing etc) to convert my non pto 450c. What would you want for the parts? Thanks, Ross
jbrown
installing pto shaft
Post by jbrown » Fri Aug 01, 2008 5:51 am
Did you ever put that pto shaft in your dozer? f so how hard was it ,in the service manual its says you have to pull motor. is that so?
Post by digitup2 » Sat Aug 02, 2008 6:57 pm
Last couple I installed I backed it up on a 8 inch log and pulled the back plate then installed the shaft ,If you get the rear up high enough [a foot even ]you will not lose any oil and you can work on it easyer even .Digitup.
