Who sells the most original looking gauges for the 440 IC? I specifically need an amp and temp gauge. I have a tach and an oil pressure gauge that are JD.
I have seen the many china knock offs with the big round bottom on the needle, no thanks. I am looking for gauges that are reasonably priced and also look more like the originals.
Original type gauges for 440 IC
- JD440ICD2006
Either Deere or Jerry Trycka at Evergreen restorations are the only correct face Dubuque gauges available. Only catch is the original style 430/440 oil pressure gauges are no longer available from any source. Jerry makes up a mechanical gauge that looks right, but you will have to run an oil line to it.
- JD440ICD2006
Lavoy, thanks for that info!
If the "correct police" don't catch me
, I am more comfortable with a mechnical oil gauge than the original electric sending unit. It just seems like there is more room for error with the sending unit set up, maybe I am wrong
Users browsing this forum: No registered users and 281 guests
