JD450 Steering clutch T.O. bearing fork removal
Hi All, I'm doing a steering clutch job on my 450 loader. Since I'm in there I want to replace the ring gear quill seals. I'm trying to remove the throw out fork and shaft. I removed the set screw but can't seem to move the fork on the shaft. Any ideas? I've been soaking it with penetrating oil, thinking maybe heat. Thanks, Brian
Users browsing this forum: Google Adsense [Bot] and 34 guests
