adjusting the steering clutch fingers 420c
In the final stages of rebuilding the left final and steering clutch in a 56 420c. Put in 7 new fibers and 6 new steels, bolted down new pressure plate, set new steering clutch gauge on the brake drum and even with the adjusting nuts all of the way down, could not get the fingers to touch the gauge (maybe .12-.13" clearance between gauge and fingers). I took the pressure plate back off and measured the height of the disks and it was 1.688" - about .055" over the specs. Any ideas about where to go from here?
If this posting works, below is the pressure plate before bolting down, just resting on top of the clutch disks.
[img] http://i153.photobucket.com/albums/s237 ... 0_0802.jpg [/img]
