skid plates
Eric.MacLeod
skid plates
Post by Eric.MacLeod » Sat Apr 19, 2008 12:29 pm
the dozer i want to keep has a small skid plate that covers just the engine it is a 58 ,420,,,i have a 57 dozer with a full skid plate from front to rear, i cant see how to take it off, it has brackets that hook to the cross shafts , it looks like the dozer frame is in the way, if im just playing outback do i need a full skid plate,thanks you might save me some time
Post by JD440ICD2006 » Sat Apr 19, 2008 1:20 pm
If you take it easy and make sure you do not cross stumps or other high spots, you should be fine just playing out back.
Be careful if you decide to take them off, those plates are heavier than they look.
Post by digitup2 » Sat Apr 19, 2008 3:05 pm
My 40c has a sod plate this is quite different than the skid plates . I see it in the parts book as a sod plate .It is half the thickness and a lot less protection than the skid plate .I have never had the 40c that deep in mud but they go through more mud with a skid plate or sod plate on as they are flat on the belly.I have crashed over a few stumps with it .So if you take yours off don't go playing in the mud or strattle stumps to aggresively that is all .Digitup.
Eric.MacLeod
Post by Eric.MacLeod » Sat Apr 19, 2008 7:47 pm
thanks that will save me some time,and you are right this skid plate is thick steel, ill go easy with it.. thanks Eric..
Stretch
Post by Stretch » Sun Apr 20, 2008 5:53 am
For what it's worth, I have two 2010's. And I believe the skid plates may aid in keeping the frame rails square while also protecting things underneath. Not 100% sure of this maybe someone out there would have a better perspective.
I do know the linkages and hydraulic lines would be prone to damage without the plates.
Just my two cents.
Stretch
2010C Dozer, 2010C Loader
The Fireman
Post by The Fireman » Sun Apr 20, 2008 10:52 pm
I just finished fabing up the front plate for my 440, 1/4 inch plate and 2" angle worked like a charm. I need to finish te back now. I've played a little with out any belley pans but boy does that make me nervous. All it takes is one small tree limb or stump to ruin a good day.
Post by Ray III » Wed Apr 23, 2008 6:52 pm
Is the sod pan listed in the parts book on page 40-1, and the skid plate on pages 50-4 and 50-5?
Looks like I have the front of the skid plate, but the back is missing. Does the back protect the final drives at all? It bothers me how low they hang from the machine and sure enough when I took one off there was a repair from when the pan had been smashed off.
Post by digitup2 » Wed Apr 23, 2008 7:30 pm
If the skid plate is as long as the newer crawlers have it goes to the draw bar plate but as mine is only a sod plate I will have to look at the old Deere out behind the shop and see what is on it.Ok I am back and it has the full skid plate to hitch considerably different than the sod plate and twice as thick .Those plates do add some structure to the crawler as well but the one on the 40c would do anything but that .The ones on the H and J series are just more than cosmetic so I dont think they do much for structure as well .Lookin at the 550 B and 450E they have a sound fastening but a few 1/2 bolts won't do much for structure Maybe on the 1010 series and to the old 450C there was structure to the skid plate .One of the Js has one bent up bad looks like sheet metal .they will probably be plastic soon .Digitup.
Eric.MacLeod
skid plates
Post by Eric.MacLeod » Wed Apr 23, 2008 8:09 pm
i looked at taking it off ,it went from front to drawbar, this thing was thick had some dents, looked like more than i wanted to tackle, sold spare dozer to friend at work,hope i dont need it,hope he can use it,,,thanks. Eric
Users browsing this forum: No registered users and 279 guests
