550A Pinion shaft
550A Pinion shaft
I finaly found a pinion shaft,does anyone know why JD used bearings in some shafts,and bushings in others?My origonal shaft has a bearing,the one I found has a buishing what is the difference?
550A Pinion shaft
NO,the final drive shaft in a 550A wide track T81196 shaft,some have a bearing some a bushing.The orignal that was in mine has a bearing the one I found has a bushing.Does it make a difference?
I have never run into one like that--it looks as thow the bearing rides on the bushing I sniped a pic out of parts book if it will help it looks like it should work http://picasaweb.google.com/yasshol/550PinionShaft
have fun Randy
have fun Randy
Users browsing this forum: Google Adsense [Bot] and 189 guests
