kiwi
Post
by kiwi » Wed Apr 02, 2008 7:19 pm
I have gradually lost both forward and reverse drive in 450C. Initially there was a delay when engaging the powershift, then it was ok for the first 5 minutes after start-up, now it only just gets ahead when not pushing in low 1.
As it occurs in both forward and reverse I suspect there is an oilpressure problem to the clutch packs. Apart from a blocked filter (cleaned recently) what else could it be? Internal oil leak, busted O-ring, relief valve???
RANDY Fay
- 430 crawler
Post
by RANDY Fay » Wed Apr 02, 2008 7:46 pm
I belive your problem would be eng clutch adj. and hyd dump valve adj. for HLR if you have a manule these adj. are made with 3/4 socket on bolt on back side of clutch pedal an under left floor plate down through hole under rubber plug in top of belhousing some take a 9/16 deep socket and some are 5/8 deep socket-- extenion I also tape the socket to the extenion real easy to loose socket in bel have fun Randy
pdmech08
Post
by pdmech08 » Thu Apr 03, 2008 9:14 am
Kiwi: If your lucky Randy is right, but of all 450's we have done 90% have issues with the reverser shaft and manifold. (Internal leakage) This requires disassembly and rebuild. If you don't have a service manual, get one. You'll need it if you intend on doing the repairs yourself. If you have any other questions feel free to email me directly. Good luck. Steve.
Users browsing this forum: Google Adsense [Bot] and 190 guests
