I am dealing with a weird problem, when i put a load on the hydraulic system say lifting the blade with weight or pushing down with the blade the hydraulic system stutters and there is a pulsation. I check the oil and there is lots and the oils new, sept last year. Is this a problem with the valve or pump, if its the pump are there rebuild kits around or rebuilt pumps. New rams and hoses in sept as well, any ideas.
Have a good one
Dave
Hydraulic pump stuttering?
- Davie Sprocket
- 430 crawler
420C Holt Blade ROPS
420-40C Basket Case
420-40C Basket Case
Dave,
Sounds to me like you are having issues with the bypass in the spool valve. Easy fix. Could be someting as simple as an oring. You may have got some foreign material in it. You can also check your pump pressure to be sure. If it is the pump should be no problem either rebuilding, I find most of my parts at local hydraulic shop. Hope this helps
Stretch
Stretch
2010C Dozer, 2010C Loader
Users browsing this forum: No registered users and 317 guests
