parting out 440 IC S/N 440321
BLS
Post by BLS » Fri Mar 07, 2008 8:12 pm
I'm parting out a 440 IC.
lots of good parts, some not so good...(that's why it is a part out)
List of good parts:
1 sprocket
transmission assy
reverser assy
center section
rock guards
1 fender with battery box and hydraulic tank
1 spring tensioner
8 bottom rollers
engine clutch housing
nose (small chunk missing out of bottom corner)
please email me at StaceyJan@aol.com if you are interested, I can send .jpg pictures
Thank you
Brian
joed5626
440 final drive
Post by joed5626 » Tue Mar 11, 2008 7:30 am
need guts for 440 final drive casting #t12912t will parts from 1010 work?
Post by Lavoy » Tue Mar 11, 2008 9:20 am
1010 internals will not work, and if you have a high serial number 440 gas, it uses it own gear set, not used in any other crawler.
