need injectors for a 1010
woody
Post by woody » Fri Mar 07, 2008 5:09 am
have a 61 model 1010 and need a set of injectors either good,new or rebuildable.any help here would be appreciated
Post by Lavoy » Fri Mar 07, 2008 11:10 am
That is probably going to be a tough one. Your best bet is to have yours rebuilt.
jdemaris
Re: need injectors for a 1010
Post by jdemaris » Fri Mar 07, 2008 4:19 pm
woody wrote:have a 61 model 1010 and need a set of injectors either good,new or rebuildable.any help here would be appreciated
It depends on what injectors are in it now. The very early 1010s had injector nozzles that were obsolete by the middle 1970s. For them, the fix was - to clean up and lap the original nozzles - or - change the holders over to the newer versions that 1010s used after serial # 29,000.
If you have the later nozzles, you can buy new ones for $20 each (if things haven't changed recently).
Your best bet is to pull the complete injectors out, then pull the nozzle tips off - and get the numbers off of them.
Tiny Crawler
Post by Tiny Crawler » Sat Mar 08, 2008 6:58 am
There is a set on ebay now if you are still looking,
Item number: 280206845667
bearman
Post by bearman » Sun Mar 16, 2008 12:28 pm
hi
if you didnt get them on ebay i have a set of four?
