420c undercarraige
- 40C crawler
420c undercarraige
Hey all just bought my first crawler a420c a 57 i believe. It was pretty nice out the day i brought it home so i played around a bit but turned cold again so haven't done much.Totally new to the crawler world so have lots of questions.First of all the rails are wore out badly along with the sprockets so wondering if any of you out there would happen to know if i could get a good used or rebuilt set of rails and sprockets - what would they be worth? It has 2 bolt pads. I'm in east central Saskatchewan, Canada very few crawlers around here and no parts.Wondering if anybody can steer me in the right direction.It needs work but engine and power train are good.Glad i found this site as it will sure help me.Any help welcome.
- Davie Sprocket
- 430 crawler
Hey john i'm in edmonton, Lavoy seems to be the closest to us for parts, plus the best prices i've seen. I'm looking for 4 bolt pads, the flatter the better. I have some 2 bolt pads but they are pretty rough. The undercarriage i have from my parts crawler is pretty bad as well. I was thinking of welding up my sprockets, two of em have field repairs.
Have a good one
Dave
Have a good one
Dave
420C Holt Blade ROPS
420-40C Basket Case
420-40C Basket Case
- 40C crawler
thanks for the input guys actually had plans of comming down Lavoys way later this spring. Ill try and get in touch with you figure something out that crawler has solid front idlers 19inch diameter I assume from a bigger crawler are they interchangable or could it be a different track frame it is a five roller bottom rollers have lots of flange whats the best way to tell if they are done for getting a heavy snow fall now might go out and pile some snow. Once i figure this out ill bend your ear for the other stuff
- bulldozerman
- 420 crawler
- 40C crawler
Branden
Not sure I understand the question The rails pins and bushings are wore so that they dont ride on the sprocket properly and im out of tightener Does it make sense to cut out a link and snug them up and run them till there dead Icant hurt anything can I Is there any hope of removing the flange on top of the exhaust manifold looks like pipe fits inside the manifold and i cant move it it needs a little repair
Users browsing this forum: No registered users and 259 guests
