Anyone with a parts manual for a 420 Crawler .
Lu47Dan
Post by Lu47Dan » Mon Feb 25, 2008 9:11 am
Would someone know the part number for the bushings that go in the idler wheel . I am waiting for my manuals to come and would like to get the bushings . Since one side is bad do you think that I should do both side while I am rebuilding the final drives ? Also need the part number for the heavy snap ring that goes on the master pin . Thanks , Dan
1956 420C with GSC blade
chickenman
Post by chickenman » Mon Feb 25, 2008 2:40 pm
Idler wheel bushings--Part# M2266T
Master pin snap ring--Part# M2679T
Didn't check to see if JD still lists them. Since you are rebuilding finals, I would replace both sides to make them alike or evenly worn.
Lu47Dan
Post by Lu47Dan » Mon Feb 25, 2008 9:32 pm
Will call my local John Deere dealer in the morning and see . Thanks for the numbers . Dan
Lu47Dan
Post by Lu47Dan » Thu Feb 28, 2008 11:21 am
The bushings and the snap ring are still available through J.D.
Bushing $26.50 each
Snap ring $3.00 each
Lets see I need two bushings per side ? Dan
Users browsing this forum: Google Adsense [Bot] and 29 guests
