MC track pads
D.Tupper
MC track pads
Post by D.Tupper » Sat Feb 23, 2008 12:04 pm
Would Lavoy or anyone else have access to stamped steel, 14" wide , 2 bolt track pads for my 1950 MC?. I do have 28 of the heavy pads located thru Ralph in Grants Pass Oregon, but could use 28 more of them to change the full set. Thanks Dennis
Post by Lavoy » Sun Feb 24, 2008 6:11 pm
Good used pads will be difficult at best to find, 14" more so, ones in the condition you want, even harder. You only choice will likely be to buy a complete crawler with the pads you want and swap them out for yours and resell it.
FarmLife
Post by FarmLife » Mon Feb 25, 2008 3:35 pm
THere is a parts crawler on e-bay right now with what looks to be 14" pads, which you could probably run off with pretty cheap. THere may only be enough pads to make one full set of good ones, but it is worth a look.
Here is e-bay item number 330214814812
1934 GP Beaner
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1937 A w/behlen overdrive
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
