pricing on big gear in final 1010
brian
Post by brian » Mon Aug 08, 2005 6:06 pm
lavoy, I purchased the little gear and clutch plates from you and recieved them I thank you very much. After removing and cleaning the big gear,the inner tappered splines are worn really bad. I was wondering if you had this gear. The numbers on gear read as follows
T14588T*
T17491T
It has 56 teeth thanks again for things I've recieved from you
Brian
Post by Lavoy » Mon Aug 08, 2005 9:13 pm
Brian,
If it is the coarse spline (6 splines) gear, the only thing I would have is new, they are $400 + freight.
