gearmatic winch
cat10til2
gearmatic winch
Post by cat10til2 » Sat Feb 02, 2008 8:23 pm
I am attempting to pull the side cover off my winch. I have removed the row of bolts around the outside, but the cover doesn't want to come off. Is there a trick to getting it off? I don't have an manual for the winch. Anyone have one or know if they are available still? Any help is greatly appreciated. :D
thanks
cat10til2
JD 1010, 610 blade, winch, gas
1968 case 530 CK, 1946 John Deere A, 1928 Ford Doodlebug, 1969 Minneapolis Moline with West forklift attachment
Post by Lavoy » Sat Feb 02, 2008 8:58 pm
There should be two tapped holes across from each other on the cover. Put a 3/8" bolt in them and "jack" the cover off of the winch. Be careful not to put too much pressure on them, you can break the cover in two.
Manuals should still be available from Paccar, I got one several years ago.
Davie Sprocket
Post by Davie Sprocket » Sat Feb 02, 2008 11:38 pm
I tried to get a manual from paccar, after several emails no luck, if anyone has one that they can scan and share it would be hugely appreciated.
420C Holt Blade ROPS
420-40C Basket Case
cat10til2
cover
Post by cat10til2 » Sun Feb 03, 2008 6:27 am
I saw the two holes (top and bottom) and at first thought that they were dowel pins, but closer inspection shows that they are broken off bolts. I guess drilling and tapping is in my future. Makes me wonder what is stuck so bad inside that the cover won't come loose? The control unit was stuck as well, but that is now freed up and seems like it should be usable with some new cups and an o-ring in there. The handle is also broken off. Anybody have one? :lol:
thanks
cat10til2
Post by Ray III » Sun Feb 03, 2008 8:21 am
They probably were broken off due to impatience. When you get them out, put some oil on the threads of the bolts you put in there and that will decrease friction a lot. Tighten them as evenly as possible, run them in by hand then turn snug with a wrench, then 1/2 turn to each side at a time or 1/4 turn if there is a lot of resistance. If they do not want to turn any further smack the heads with a hammer.
If the cover is ungodly stuck then heat may need to be applied, but I don't know exactly what you're dealing with so I can't say where.
JR
Stuck Cover
Post by JR » Sun Feb 03, 2008 11:45 am
I believe there are internal dowel pins that are what are making it come off hard. Also someone might have used a liquid gasket to hinder removal.
My cover came off hard but the bolts are the best way.
JR
Post by Lavoy » Sun Feb 03, 2008 12:09 pm
There are no dowels, just the bolts. What it is stuck on is the large main bearing. If your bearing adjustment nut in the center will loosen up, you can use that to push the bearing out of the cover.
cat10til2
cover
Post by cat10til2 » Sun Feb 03, 2008 5:52 pm
Thanks for all the tips. I was able to weld a 9/16 nut over one of the broken bolts and back it out that way. The other one I ended up drilling and tapping. Once that was done, I put in some new bolts and greased them up good. After careful tightening, and a little help from some well placed screwdrivers, the cover did come off. It was indeed stuck on the main bearing (thanks Lavoy). What I found inside was a mess of rusty parts. I started spraying with PB blaster and I am going to let them soak before continuing on. I am hoping that if I can get the brake band out, then the rest will come loose.
Other parts of the tractor are coming well. Both finals are rebuilt and reinstalled. The reverser cable is now operational. I am waiting on some new to me rollers and then I can replace the track frame and put the old track back on. I still have some governor work to do and will probably rewire the tractor. The harness that is there now is such a mess, it will be simpler to star over I think. It will probably sprout an aternator and avoid the generator / regulator headache as well. I have the push frames cleaned up and ready to weld a new beam inbetween them so that the blade can go back on too.
No shortage of things to do....this is a great BB....thanks to all for your help and advice. :P
cat10til2
Post by JD440ICD2006 » Sun Feb 03, 2008 7:47 pm
Glad you got that cover off without cracking it, that is always a good thing.
I hear from time to time that water, yes water, is as good as anything for loosening rust. Even if it works slower, you have admit that the cost is lower than the spray cans of miracle oil.
karsonb
Re: gearmatic winch
Post by karsonb » Tue Mar 18, 2008 10:10 am
cat10til2 wrote:I am attempting to pull the side cover off my winch. I have removed the row of bolts around the outside, but the cover doesn't want to come off. Is there a trick to getting it off? I don't have an manual for the winch. Anyone have one or know if they are available still? Any help is greatly appreciated. :D
thanks
cat10til2
I do not have a vintage JD crawler, but do lurk on this site as it has much good information. I have an old Garrett Log skidder, that is equipped with a gearmatic 8A winch. I bought a manual from Garrett Enumclaw,
in Enumclaw WA, from Don Garrett, for $40.00 It is a complete winch manual, though a copy, but a good one. He also has a line on 8A parts.
Don Garrett (360) 825 2500. Keep thes old soldiers going!
Karson
jdemaris
Re: gearmatic winch
Post by jdemaris » Wed Mar 19, 2008 6:36 am
cat10til2 wrote: I don't have an manual for the winch. Anyone have one or know if they are available still? Any help is greatly appreciated. :D
thanks
cat10til2
Have you tried their website? They have a lot of vintage winch manuals on-line, free for PDF download.
cat10til2
it's alive
Post by cat10til2 » Sun Mar 23, 2008 8:40 am
Well the old 1010 is running after many hours of work. The blade is on and back in one piece, the wiring is all new with a alternator and the tracks back on. I pulled it outside to push a little snow and it seems to work pretty good. It will push until it tries to stall the engine. I need to adjust the brakes a bit though, it isn't applying the brake enough to steer very well.
Next is to decide whether to put new chains on it or to search for a used set. I am leaning towards the new set and being done with it. I can get them for about $1600/pr plus a box of new bolts.
I haven't gotten back to the winch in quite a while. It is now at the bottom of the to do list and might have to wait until next winter.
cat10til2
Users browsing this forum: Majestic-12 [Bot] and 13 guests
