2010
steve243
2010
Post by steve243 » Wed Aug 03, 2005 1:33 pm
my 2010 diesel crawler wonts to die when backing up a hill nothing real steep also is the winch supost to disengage when clutch is pushed in
2010OWNER
Post by 2010OWNER » Tue Aug 09, 2005 1:57 pm
Steve,
Sounds like one or both of your fuel supply lines is a little plugged up. If I remember correctly, there are two supply lines and one return line on your tank.
Regarding the winch; on mine there is a little lever at the back of the cat to disingage the winch drive. The clutch pedal has no effect. If you pull up on the "disconnect" lever under your left foot, that will stop the winch drive also.
Brian
