Turning shaft
440 CRAWLER
- 40C crawler
Turning shaft
Just wondering if anyone has ever turned the upper idler shaft to bring the unworn side to the top
seems like this could work ?
440,
I was sort of wondering the same thing. I have two pretty much sacked out on my 420. I just don't have a big press, or I probably would have already tried. The press is on the drawing board. Right behind the 420. Carts and horses and stuff, or chickens and eggs. I never could get any of that quite right.
Gary
Gary
okie dozer
upper shaft
Found the same problem on our 420. Obtain the upper replacement bearing. start laying in arc welder beads/mig beads roughly to the required dimension and roughly finish with a large flat file. You'll probably find the very outer end of the shaft is not totally worn down and will make a good welding guide. A mic or caliper will help. Approx 2-hours work and polishing machinist's tape finished it to a near perfect fit. good luck
That's good to know. I only tapped on it lightly, and backed away. I haven't had time to work on any of it, though. My son needed a shop, so we built that, and now we have some travelling in front of us. I hope to get back to it ernestly in September.
How much are the shafts? Bushings? This is for the upper roller.
Gary
Gary
440 CRAWLER
- 40C crawler
Users browsing this forum: No registered users and 54 guests
