Stripped Mounting
Trich
Stripped Mounting
Post by Trich » Sun Dec 23, 2007 5:30 pm
On my 1956 420 there is a 3/4" bolt that secures the floor plate to the side of the fly wheel housing with a bushing. The threads in the fly wheel housing have become worn to the point they will not hold a new bolt. I am thinking I will need to drill the hole out and tap it up to 7/8. Is this the right way to go?
Post by JD440ICD2006 » Sun Dec 23, 2007 6:48 pm
This sounds like it may be a good candidate for a HeliCoil. It comes with the proper drill to drill the hole, then you thread in the coil. It makes a great rethread back to your original size.
They are available at most of the chain auto parts stores, along with TSC and others.
http://www.emhart.com/products/helicoil ... Ggod5H_JWA
Post by Ray III » Sun Dec 23, 2007 9:53 pm
I just got a 3/4" HeliCoil kit, it was $80. OUCH! That is probably not the last place you will ever need a 3/4" thread repaired on that machine though.
Users browsing this forum: No registered users and 223 guests
