catmatt
- 40C crawler
Post
by catmatt » Sun Dec 16, 2007 8:39 pm
How do I remove the starter from a MC crawler? What Gauge of wire should go from the battery to the starter? Is that part on the outside of the starter available from JD? The part I am talking about is the one which you pull the handle to engage the starter, ie the switch?
- Site Admin
Post
by Lavoy » Sun Dec 16, 2007 10:06 pm
You have to remove the RH side of the batter sheetmetal, then there is a set screw that holds the starter in. Wire should be at least #1 copper.
Switch is readily available from Deere or elsewhere.
catmatt
- 40C crawler
Post
by catmatt » Mon Dec 24, 2007 6:42 am
Thanks lavoy for the help. I pulled the starter this weekend. FYI- you don't completely have to remove the RH side sheet metal as I had the hydraulic valves in the way to prevent total removal. YOu can slide the sheet metal towards the seat to create enough room to pull the starter.
- Site Admin
Post
by Lavoy » Mon Dec 24, 2007 10:35 am
Matt,
I should have told you that, sorry, wasn't thinking about the valve.
