Old Miss. Forestry Commission dozer. Was JD Green under all the yellow paint, so I decided to go back to all green. Early '56, so no yellow on hood.
http://www.jdcrawlers.com/uploads/jdcrawlerbefore.jpg
http://www.jdcrawlers.com/uploads/jdcrawler1.jpg
1956 420 Before and After Pics
- 420 crawler
- JD440ICD2006
Looking good! I am guessing the grousers are welded up? If not, that is the best set of two bolt pads I have seen.
- 420 crawler
1956 420
Grousers show no signs of being welded up. Can't swear that they are the ones that came from factory, since the dozer had several previous owners before I bought it. Engine had <than 100 hrs. since being rebuilt and pins and bushings had <10 hrs. since being replaced. Did have to put in new(used) drive shaft and put in center section from a 40 wheel tractor since the one on dozer was cracked where it bolts to transmission case. Mostly just lots of wire brushing, sand blasting and painting. Also replaced pipe on cage or limb riser or whatever you want to call it.
- Contact:
Re: 1956 420 Before and After Pics
That is fun to look at!chickenman wrote:Old Miss. Forestry Commission dozer. Was JD Green under all the yellow paint, so I decided to go back to all green. Early '56, so no yellow on hood.
www.flatlandauction.com Buyer and Seller of all types of Equipment
