iam in the process of assembling my final drives, new bearings and seals is all that seem to be needed. however as the final drives are put back i noticed that the teeth on the gears dont match up completely. The 14 tooth pinion gear and the 55 tooth drive gear are offset about 1/4 inch. the 55 tooth gear looks like it could be moved over to make up the difference.
What iam i to do, i assembled the final drives the same way i took them apart. Iam pretty sure that the drives have been worked on in the past. Can i use a shim to make up the difference? there is already a "special washer" as per the parts cataloge in place. Is there any place where i need to measure for tolerances? the manuals i have are not all that clear on this issue.
thanks for any advice
jd 440icd final drive rebuilding....help
- 430 crawler
- 430 crawler
Always remember when installing axle shafts to make sure the bearing is seated all the way against the spacer, and the spacer is against the bull gear. On time I assembled a final, thought I had it done, and then looked in the bottom, and could see a gap between the spacer and the bull gear. Turned out I had done the same thing as you. Now when I put them together, I hit outward on the axle flange, as well as reach up from the bottom and see if I can turn the bushing with a long screwdriver.
Users browsing this forum: No registered users and 414 guests
