1949 MC crawler
das9789
1949 MC crawler
Post by das9789 » Sun Dec 02, 2007 3:09 pm
I have a question about my MC crawler. Should the right brake pedal and the left clutch pedal operate independantly? I have replaced the left side steering clutches and in the attempt to adjust the throwout bearing I noticed that the pedals move together. Also does anyone know where I can buy a left side pedal? The one I have is cracked where the shaft goes through. Thanks Dave
FarmLife
Post by FarmLife » Sun Dec 02, 2007 5:06 pm
THe clutch shaft is basically a tube that the brake shaft rides inside of. So it is possable that the clutch shaft and brake shaft are seized to eachother. Probably will just have to remove the both of them and try to seperate them.
1934 GP Beaner
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1937 A w/behlen overdrive
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
Post by Lavoy » Sun Dec 02, 2007 7:04 pm
Yes they should move independantly, they are just stuck together. I might have a pedal, I can check if you want.
Users browsing this forum: No registered users and 393 guests
