MC Shifter
FarmLife
MC Shifter
Post by FarmLife » Sun Nov 25, 2007 9:55 pm
Is there some sort of button that goes on the end of the shifter (where it contacts the shift forks) because there is nothing on mine and the shifter is so sloppy it spins in the housing and goes all over the place. Also can shift forks be welded and built back up and ground to spec or is there is a place that makes new ones (or am I just better off trying to find a good used one)? As always thanks for the help.
1934 GP Beaner
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1937 A w/behlen overdrive
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
Post by Lavoy » Mon Nov 26, 2007 8:40 am
Should be a "ball" of sorts on the end of the shifter. Forks can probably be bronzed up and ground down, I have seen it done before.
I have shifter and trans top covers on hand, if you just want to replace it.
Users browsing this forum: No registered users and 392 guests
