Manual adjuster
kyboy
Manual adjuster
Post by kyboy » Thu Nov 22, 2007 6:49 pm
How does the manual adjuster work? how does the grease adjuster come out? lavoy,do you have any of these? how much are they. a portion of the head of ours chip off and losses grease and wont hold tension on the track. is there any other ideas how to fix this.thanks for the info.
gary
Post by Lavoy » Fri Nov 23, 2007 10:27 am
The manual adjuster is just a threaded rod on the idler, and a big nut welded to the adjuster pipe. They work fine until they rust up.
I may have a used hyd adjuster, and can get new aftermarket ones.
kyboy
1010 track adjusters
Post by kyboy » Fri Nov 23, 2007 5:24 pm
if you have a good used hydraulic one that would be great. If not,how much would the new ones be? hydralic or manual?
gary
Post by Lavoy » Fri Nov 23, 2007 5:40 pm
Gary,
I would have to check on a used hyd, new hyd are about $320 give or take. They do not look like original if you are concerned about that, but function great. No new manual adjusters, truthfully I had not thought about it until now, but I have a rusty one to use as a pattern, might look into it.
Send me an e-mail and I will check more next week, will be gone for part of the weekend.
