fiber disk replacement on jd 440 icd
frozendozer
Post by frozendozer » Thu Nov 22, 2007 11:08 am
thought i had a failure on a stearing clutch on my JD 440 icd. when i took it apart to replace, i saw that the seal had failed and that the breal band and clutch disks were completely covered in gear oil as well as the brake band. my question is as follows:
di i need to replace all the fiber disks and the brake bands. They are all in real good shape and have cleaned up real nice.
thanks all
Stretch
Post by Stretch » Thu Nov 22, 2007 11:53 am
If the discs and band is soaked in oil I would change them all. They will soak up the oil and swell up and no matter what you do you will never get them right. :(
Check with Lavoy for certain though.
Stretch
2010C Dozer, 2010C Loader
Post by Lavoy » Fri Nov 23, 2007 10:29 am
The brake band may live, but it will always bleed oil and not work as well. The fiber discs are junk, been there done that a couple of times and learned my lesson.
oil soaked band
Post by mini kahuna » Fri Nov 23, 2007 11:55 am
Lavoy and stretch are right on,oil leak into clutch compartment.... replace the brake band and fiber discs....they won't work right ever again once oil gets soaked into them.
1010 loader
frozendozer
Post by frozendozer » Thu Nov 29, 2007 2:31 pm
thanks all for the advice, it supports the scuttle but i heard here. will be placing an order for new stuff soon.
frozendozer
Users browsing this forum: No registered users and 411 guests
