flanged axle shaft wear
I got both final drives tore down. The only area of concern found is on the flanged axle shafts, where the triple lipped seal rides. There is a measurable amount of wear and uneveness is this area. Rebuilt axles,from the local dealer are $345.00 a piece plus shipping. What are your thoughts and experiences? Any ideas on what would be acceptable wear would be appreciated. Mark
- DiggerLarry
- Contact:
I can certainly do a od build up using gtaw welding to keep the heat input low. I don't imagine that the axle shaft surface wear the bearing race will ride is a hardened surface, so that a little heat should not bother it? I am not a tool and die maker but I'm sure I can turn the shafts down after welding to provide a smooth even surface for the seal. Any thoughts on this proposal? Mark
- FarmLife
- 430 crawler
- Contact:
I know you can get thin collars that go over the seal surface on pinion yolks on vehicles. I beleive they also make these in universal sizes so you may be able to find one that will fit the crawler axle and that would keep you from having to weld the shaft.
1934 GP Beaner
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1937 A w/behlen overdrive
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
1935 B
1935 AR
1935 AO
1936 B
1936 D
1935 A on skeletons
1939 B
1940 B
1941 H
1949 M
1954 40 Standard
1953 60 Regular
1955 70 Std Diesel
1954 80
1946 Lindeman
Phase 1 420
Once again thanks to all for the input. Lavoy I was given a old but never used oxy/acetylene powder welding set up (spray) in lieu of payment for a job I did, but thats another story. Unfortunately it is missing a few pieces and I have not been able to set it up and try it out. I do not believe that the seal surface part of the shaft has to be all that hard, as a rubber seal will ride on it. The only difference might be that the welded surface could wear faster than a hardened surface in service. From the wear present on the axle shafts I would not guess that they were all that hard to begin with. Mark
Last year while rebuilding a 16hp single cylinder engine I was close to tolerence on the crank . I priced chroming the journal. Between $450 and $500. I was fortunate enough that there was some extra meat opposite of the wear and was able to move the center of the pin which wound up stroking the thing 0.015". Chroming is to spendy for any but racing or last ditch moves.
If it is a standard inch size there are hardened bushings you can get for inner races of needle bearings.Turn the axle down and press one of these on and fixed forever,I've used these for bushings in the whole blade assembly for all the pivots on a 61 blade ,from the A frame end holes to the lifting links, they are the same as the bushings you would get if you were rebuilding a newer JD dozer.
58 420c w 61 blade and 3pth and pto,57 420c w loader,48 D,48 M,Allis D-15 and a Super Duty to haul these!!!!
I have been getting them at local bearing supply stores, One brand name is Torrington,I know we have got them at work from Macmaster Carr also.The only problem is they are ground to exact size ex. 1.750" so the pin or shaft you are using has to have the clearance on it,the bushings can be machined but they are very hard.
Been thinking about this one for a few days. The jet powder spray setups generally have a few different powders you can select from to get whatever hardness you'd nee. Check the Stoody site and you'll see about 8 different powders.
The other thing I thought of was using a Stoodite 6 (or Stellite 6) bare rod with a gas welder. You could get the same result with TIG but I'm still saving up for that. The Stoodite 6 is in the range of Rockwell Rc42 for hardness and is machinable with carbide tooling.
Users browsing this forum: No registered users and 392 guests
