carburator floats
CELSESSER
carburator floats
Post by CELSESSER » Wed Nov 07, 2007 6:50 am
Hey all,
What makes the floats collapse in on these Marvel-Schebler carbs?
If they are dry and not leaking and only slightly concave on one side do they still exert as much pressure on the fuel shutoff needle? Is this a reason for the fuel leakdown problem or are they by design not boyant enough to keep the needle valve closed tight enough on the seat?
Chuck
Post by Lavoy » Wed Nov 07, 2007 8:55 am
I don't know what causes that, but I have seen numerous ones that way. If not dented too bad, they will still work.
Must fuel leakage problems are with the needle and seat being bad somehow.
brettjones
Post by brettjones » Wed Nov 07, 2007 3:33 pm
I'd guess it's a heat issue from when they're brazed.
JD 1010c, outside blade, winch
Mace Canute
Post by Mace Canute » Sun Nov 11, 2007 12:21 am
Awhile back I came across an explanation someone had given for this....brass floats will be collapsed if water accumulates in the float bowl and freezes. It takes quite a bit of water to do this but apparently it does happen. The ice expands and pushes upwards against the float which it can`t go any higher so it collapses.
Users browsing this forum: No registered users and 202 guests
