440icd engine difficulty in turning over
bhajd440c
Post by bhajd440c » Wed Oct 17, 2007 9:25 pm
1959 John Deere 440 ICD won't start. Engine ran fine one day, the next it wouldn't turn over. Replaced battery, rebuilt starter, no help. Connected battery to starter directly, bypassing cables, no help. Oil seems okay, no sludge. No oil and coolant mixing that I can see. Removed hydraulic pump, no help. Requesting assistance in diagnosing problem.
1959 440ICD
Post by JD440ICD2006 » Wed Oct 17, 2007 9:33 pm
If your good battery and starter will not turn the engine over, there is apparently something gone wrong inside. I would check the blower to see if it seized or is binding. If it is correct, you will need to at least drop the oil pan to see if you can locate anything wrong.
bhajd440c
Post by bhajd440c » Wed Oct 17, 2007 9:52 pm
Thank you for the advice. I was debating whether to pull the pan or the head. So I'll go for the oil pan first. Thanks also for the forum. It is a great resource.
emichaelhaynes
Post by emichaelhaynes » Wed Oct 17, 2007 11:15 pm
Before you start pulling things apart...
If you have an inch and a half socket, it'll fit on the nut on either the cam or balance shaft weight. Try rocking it both ways to see it it will move. If you got water in a cylinder, hand cranking the engine backward will allow it to clear via the air box.
Also a good way to set your valves and injectors.
michael
shinnery
Post by shinnery » Wed Oct 17, 2007 11:18 pm
There is a geartrain on both ends of that engine, you might try to see if it will turn backwards. I think before I pulled the pan off I would remove the blower and/or governor to see if this freed it up. Possibly also the fuel pump. The pan and then the head would be my last choices.
bhajd440c
Post by bhajd440c » Thu Oct 18, 2007 10:09 pm
Thank you to everyone who responded to my query. When the weather here in the Northwest calms down a bit, I will try the recommendations submitted. I will keep you posted on the results. Hopefully one will be the solution I search for.
Users browsing this forum: No registered users and 162 guests
