JD 350B Steering issues - Newbie
Hello, all. I just took delivery of a new-to-me jd350B crawler circa 1981. Steering prior to delivery was fine, but in the last week, it'll run and steer fine for about 5 minutes after startup, but then left steering will gradually bleed off until I can't steer left. Right steer works fine. Thinking hydraulics, but thought I'd ask some experts. Any help would be appreciated. Thanks, Tim
I thought the 350Bs were "dry" clutch steering and also in the early 70s, not 80s? I guess it could be a late serial number 350B though- I think some of them were "wet" clutch steering. I'm sure Digitup or others will be able to give you some ideas when they see this.
BTW, welcome to the board!
I believe they are dry clutch machines too,not sure when they went to wet clutch system,Digitup will know when.
if it is indeed a dry clutch,slipping or not steering after warming up is a classic syptom of oil contamination of fiber discs and brake band,you'll have to rebuild the clutch and find the source of the oil leak.
the wet clutch systems has it's own problems,again Digitup is your man for those buggers.
1010 loader
Do not tear it down just yet the 350-350B as well as 450 and 450Bs were known for clutch fade.They would get warmer and start to fade.Set the clutches up and make sure that the brakes are set up right as well .We set those @&%$ things up every week when we only had them to work with .When the oil clutches came out I was darned glad for them .At that point I could set dry clutches in the dark and some times did .On the 450 and 450B we also put grease fittings on the steering leavers right at the pin and greased them often.This made a big difference if you ran them all day or even if just occasional use. This way they did not bind up .Digitup.
I did the clutch setup that was listed in the operators manual. It seemed to work after that and I actually took the machine out and did some work with it for about 2 hrs. On the way back to the house the left steering started going away and by the time I parked it the steering was almost back to where it was before. Any ideas? It was working perhaps just a bit more on the brake?
Users browsing this forum: No registered users and 37 guests
