Advice MC
Advice MC
I'm new to the list and crawlers, but have learned a great deal reading previous postings. I'm looking for some advice regarding an MC I found out in the woods. The owner was using it,then covered it for the winter 4 years ago, couldn't start it next spring and there it sat. I can have it if I can get it started. The starting should be no problem, and the drive and steering clutches don't appear to be frozen, but the undercarriage looks bad. The rollers appear to have been cut out with a torch and new ones welded in. The welding was poorly done because three of the rollers have broken the weld and flop around freely.
My question is, do I get involved with this thing, or leave it in the woods? Can the rollers be repaired for a reasonable amount of money or would I be better off spending my money else where.
Well, this is only an opinion but here goes. Based on what you said about the rollers, it makes you wonder what else you're going to find. In the end it really depends on your goals. If you're thinking you're going to get to a usable crawler cheap, that's not going to be the case with this one.
Lavoy had replied to a similar post I had put of the board last year saying that you shop for a good undercarriage. A year later it makes perfect sense after I've spent time and lots of money getting an undercarriage restored. Not knowing what kind of welding was done to the rollers and the impact to the track frames, it's hard to say how much it would take to fix it, but the mindset of the person that maintains a crawler the way you describe would have me looking elsewheres unless you just want a project and you don't care if you have to scrap it or part it out in the end.
Thanks for the reply. I pretty much knew it was a lost cause, but needed a second opinion. Those crawlers really are evil. Several times I'd pulled the tarp over that crawler and told myself "don't ever come back out here because its not worth it". The next weekend I'd be back out there with my tool box, early in the morning before anyone had woken up. I think I'm done now though....I think.
Thanks Again,
Markus
Thanks Again,
Markus
I would think that if you can get it free, it is well worth retrieving for resale as a parts crawler at the very least like previosuly stated.
I appreciate the input. I've really enjoyed the hours I've worked on the MC so I won't give up on having a crawler just yet. My plan is to spend a little more time on it to get it started, then move it to a place where it can sit safely. At that point I'll invest in some user manuals to better understand these tractors, and start looking for a better crawler and use this one for parts.
Markus
Markus
Hey Markus-
Did you see that Lavoy had a disassembled MC for sale in the "Little Shop O' Deeres" forum? Might be worth a call or e-mail for you.
Users browsing this forum: No registered users and 277 guests
