New Member with a 420 with sticking steering
Hi everyone. I have been a viewer of this site for a while and finally registered. I do lots of reading of past and present posts to help with some issues on my 420.
Right now I am having trouble with my right steering sticking. Sometimes I can pull the lever a little and the side will lock and then slowly move again. It feels like it always has some resistance on it. I was wondering what kinds of adjustments may be made. The right lever is about a inch further back than the left?
Any info would be great and love the site. Scott
Scott Heikkila
sounds like the break is comeing on to soon. the break can be adjusted by removing the cover on top of the drive and backing off the screw on the lever. there should be some free play in the lever before the throw out hits the presser plate then once the clutch is fully released the break is engaged.there is full proceedure in the book with measurements but that is not sitting in front of me right now.
now as far as the lever sitting an 1" back the rod that connects lever to throwout needs to be adjusted, also may not be pushing the TO all the way to full release
welcome to the board
nick
nick
Hi Nick, thanks for the advice. The right side has been sticking a little for a while but I kinda ignored it. Now I have the crawler sitting on the side of a sand bank and cannot get back out because the right side has too much pressure from the sand etc. to help out. This is what I get for waiting to fix it. Scott
Scott Heikkila
yea there slipping, check to make sure the TO is not touching the pressure plate when the clutch is engaged to drive, any pressure on the plate will allow it to slip when loaded. if one track spins out both should spin out. also i had troubles with mine that oil seal was bad on the trans side and leaked to the break band. so look for any oil, it should be dry as a popcorn fart in there.
check adjustments first then go from there
nick
nick
