420c right steering issue
454BBGB
Post by 454BBGB » Wed Jun 27, 2007 7:14 pm
:shock: can someone steer (haha) me in the rite direction . i have picked up a 57 420c with rt steering issues .. adjusted throw out bearing. pull outer case off and reviewed discs , cleaned and reassembiled . still same issue .. put into a pile of dirt . only getting drive off left track .. new to the crawlers .. could this problem be in final drive assembly .. Thanks to all ..454BBGB. :D
Post by wwattson » Wed Jun 27, 2007 7:31 pm
Lavoy is probably going to be your best source of info on this one but it could be a few different things. Did you adjust the steering clutch pressure plate using a JD-7 pressure plate gauge? Could be the levers are pressed in enough to release the clutch due to wear.
The final drive could have a stripped pinion or worse but it seems like you'd notice it from all the parts in the final drive making bad noises.
I'd bet on the clutches but Lavoy has seen hundreds to the two I've had apart.
Post by Lavoy » Wed Jun 27, 2007 8:55 pm
Bill pretty much hit all of them, might add stripped splines in rear end. Look to the clutches first. Pull the little top cover on the clutch housing and leave it off. Work the crawler, and see if the brake drum is turning when that side quits driving. If it does, it is in the clutch area somewhere. If not, it is in the final somewhere.
I said this wrong, Don caught it.
If the drum turns, then it is a final drive problem, if it does not, it is clutch or splines problem.
donol60
420--steering
Post by donol60 » Thu Jun 28, 2007 9:15 am
Lavoy, If the brake drum is not turning when a track quits pulling, indicates slipping clutches or splines, not final drive problems, correct me if i am wrong, it happens all the time. Don
old style straight blade
Post by wwattson » Thu Jun 28, 2007 10:07 am
Donol60,
You and Lavoy are saying the same thing. The drum is attached directly to the pinion shaft of the final drive. If the drum is turning but the final drive isn't, it's pretty much got to be in the final drive. If the drum isn't turning, either the clutch has to be slipping or the spline in the transmission output is stripped.
donol60
420 steering
Post by donol60 » Thu Jun 28, 2007 11:12 am
Lavoy, says, (quote ) see if drum is turning when that side quits driving------if it does ( turn ) it is in the clutch area somewhere- ----- ( end of quote ) Here is where i disagree, if the drum is turning the clutch IS NOT the problem area. Don
Post by Lavoy » Thu Jun 28, 2007 11:13 am
Don is right, I said it backwards.
Post by wwattson » Thu Jun 28, 2007 4:13 pm
If Lavoy said it backwards and I understood it frontwards, what does that make me? (Be kind please)
Post by Stan Disbrow » Fri Jun 29, 2007 8:56 am
Sideways? :P
Post by wwattson » Fri Jun 29, 2007 9:18 am
Nailed it! And that'd be the way you're going with one side not working.
donol60
420 steering
Post by donol60 » Fri Jun 29, 2007 10:08 am
Hi, WWattson, Just like the rest of us uns,--plain regular ol humanoid
that is just MHO
neil
brake drum turning or not show
Post by neil » Mon Jul 02, 2007 10:46 pm
I really enjoyed the show guys--------- had a nice little chuckle
454BBGB
Post by 454BBGB » Wed Jul 04, 2007 2:21 pm
Thanks for all the input .. think i have found the problem .. fibers may be to far gone . anyone know were i can find specs on thickness of fiber ?? Thanks agian to all 454BBGB :)
Post by wwattson » Wed Jul 04, 2007 2:59 pm
This previous post should help you.
http://www.jdcrawlers.com/messageboard/ ... .php?t=933
454BBGB
Post by 454BBGB » Thu Jul 05, 2007 4:30 pm
Thanks for the info should help a great deal in the project at hand .. :P
what a wonderful site for the crawler world of JD. My hats off to all .. Thanks again ..454BBGB
Users browsing this forum: No registered users and 214 guests
