Sticky Loader Lift Valve
jd440
Post by jd440 » Thu Jun 21, 2007 10:14 pm
Hello,
The control valve for raising and lowering the loader on my JD440IC has become sticky. It takes more force to activate the valve and it can stick on causing the loader to keep on dropping or lifting. Sometimes, I have to force it back into the neutral position. This occurred overnight. One day it was fine, the next it was giving me problems. Any idea what is happening and how I can fix it?
Thanks,
Derek
Post by Lavoy » Fri Jun 22, 2007 8:05 am
Sounds like one of the o-rings has let go, or there is something in the valve.
jd440
Post by jd440 » Fri Jun 22, 2007 9:18 am
Should I pull apart the valve assembly and check for failed components and debris?
Derek
Post by Lavoy » Sat Jun 23, 2007 9:48 am
I think that is the best thing to do, I can not thing of anything else causing it.
Users browsing this forum: No registered users and 169 guests
