1010 crawler loader
woody
1010 crawler loader
Post by woody » Fri May 25, 2007 9:33 pm
hey guys just got my 1st one last weekend at an auction 1010 diesel with loader,5 rollers and wieghts on back also has reverser on it I need to know what this machine wieghs any help would be greatly appreciated
Thanks,Woody
Post by wwattson » Sat May 26, 2007 2:42 pm
Hi Woody,
Welcome to the group. If you do a search on the board for 1010 and weight you'll find a few previous posts. The answer partly depends on he counterweights install and the loader type but I would guess in the neighborhood of 8500 pounds.
It looks like a slow weekend on the board but hopefully Lavoy or Andrew or one of the other guys more familiar with the weights will check inn at some point and set me straight if I'mm off by too much.
JD430C
Post by JD430C » Sat May 26, 2007 6:07 pm
hi woody, weight of the 1010D with loader is 9800. my brochure doesnt say anything about the counter weights, but i am guessing up to another 1000 depending on how many u have.
andrew
Post by Lavoy » Sun May 27, 2007 9:31 am
That must be without weights, I know a 420 with a 90 loader weighs 9,000lbs, so I would think a 1010 should add almost a ton to that.
JD430C
Post by JD430C » Sun May 27, 2007 10:33 am
yes thats without the counter weights. the brochure doesnt say how much the counter weights weigh.
andrew
Post by wwattson » Sun May 27, 2007 3:57 pm
Woody,
I'm guessing the reason you were asking is to know how much trailer it was going to take to haul your crawler. It's looking like a 7 ton minimum trailer because a 5 ton isn't going to make it once you account for the trailer weight.
I'm assuming that a 7 ton trailer weighs about 1.5 tons empty and the crawler doesn't exceed 11000 pounds with the counterweights. A 10 ton would be more than enough.
Users browsing this forum: Google [Bot] and 341 guests
