I need to move my 2010 crawler, but was wondering how much it weighs. Thanks
Kevin
2010 weight
2010 with loader weight
I ran a 2010 with loader across the scales back in Jan. It weighed in at 6.4 ton.
Not sure how much of that was loader.
Mark
Mark
JD 2010 Crawler with Loader
I believe the loader part of the 2010 is a couple thousand pounds- I can tell you after I get home from work as my manual has that information.
The guy that sold me my 2010 crawler loader/Model 50 backhoe used a 3/4 ton diesel pickup with heavy duty gooseneck (21K) trailer. He said he pulled it all the time with that setup.
I would say you would be ok . I don't know what manufacture your trailer is. Some trailer manufacturers rate their trailers as laden capacity and others will rate as gross capacity, meaning you would have to deduct the weight of the trailer itself. I don't know where you live or where you plan to haul to,but, you may want to make sure you are registered to haul that weight or you could end up paying a stiff fine. Just my two cents.
Stretch
Stretch
2010C Dozer, 2010C Loader
