jgbanshee
- 420 crawler
Post
by jgbanshee » Sat May 05, 2007 5:33 pm
The rubber boots that were covering my fuel injectors on my 450 are rotted and no longer there. While running the motor, I can see diesel fuel on top of every one where the adjustment nuts are located. It smells like diesel too. Why is that?
- Site Admin
Post
by Lavoy » Sat May 05, 2007 7:22 pm
I am not familiar with the 450, but if they are like the ones used on the 404 diesel engine, the rubber boots are the return. IF they are rotted, then you are leaking fuel all over.
lavoy
jgbanshee
- 420 crawler
Post
by jgbanshee » Sun May 06, 2007 6:46 am
Can I replace them?
digitup
Post
by digitup » Sun May 06, 2007 7:08 pm
There is a rubber tee kit and I replace with a brass tee and nerl fittings kit.I think I had to use some Weather Head fittings as the kits are getting hard to find last time .When these tees start to go they will let in a lot of dust to contaminate the system .So replace the fuel filter after the tees are in place . If you have a blower fan you need to pressure wash the rad out also.Dust is a good insulter and the hot weather is just ahead .Digitup.
jgbanshee
- 420 crawler
Post
by jgbanshee » Mon May 07, 2007 7:39 pm
Where can I find these tee's? I am not sure I know what you are referring to when you say nerl. Do you have website or link for these?
digitup
Post
by digitup » Wed May 09, 2007 4:01 pm
Any good parts shop should be able to get Weather Head fittings just take them the tubing outside diameter and the rest is easy .If you are close to Lavoy he may be able to get them for you .Digitup.
